It is currently Sat Jul 26, 2025 5:54 pm
 Post subject: Rolling pin sander
PostPosted: Fri Feb 04, 2022 6:07 am
Just got the total costs in to buy and import into UK
Elevate Rolling pin sander + 2 extra wraps P120 absasive comes to £246.41 = $334.11,
Hope it's worth it!
These users thanked the author Colin North for the post: Hesh (Fri Feb 04, 2022 10:26 am)
 Post subject: Re: Rolling pin sander
PostPosted: Fri Feb 04, 2022 12:21 pm
State: West Somerset
Country: UK
Do let us know Colin.
PostPosted: Fri Feb 04, 2022 3:25 pm
Online
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
If this will be your first time using a rolling pin sander, use it with caution on the first go especially if you have 80 grit on it. It's surprisingly easy to sand through a side.
PostPosted: Fri Feb 04, 2022 4:25 pm
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
I mark up the sides with pencil and sand it off. This exposes the low spots. I repeat until level or I decide the low spots are do deep and look toward alternatives to level. The pencil lets me see where I already sanded.
These users thanked the author johnparchem for the post: ballbanjos (Fri Feb 04, 2022 4:54 pm)
PostPosted: Fri Feb 04, 2022 4:57 pm
Online
First name: Jay
City: Bothell
State: Washington
That's exactly what I was doing when I sanded through a Macassar ebony side. The wood was highly figured and the surface was wavy after being bent in a bending machine. I cross hatched the sides with a China marker to do what you describe. It was my first time using a rolling pin sander and, unfortunately, I didn't realize just how aggressive the 80 grit on the sander would be. I suddenly noticed that a patch of the wood along one edge was changing color from ebony black to reddish brown and then quickly realized that was the color of the mahogany lining. Many, many bad words were said.
PostPosted: Fri Feb 04, 2022 5:11 pm
I have a rolling pin sander but won't use it on sides anymore due to this issue.
PostPosted: Fri Feb 04, 2022 7:08 pm
First name: Brad
Last Name: Combs
Colin, I know it’s yet another tool and all tool purchases lead to the purchase of more tools, but… this was recommended in the group some time back and I really like it. I have way better control of the rolling pin sander and options for lower speeds helping to avoid sand through. My uke sides are bent at .065 or so and it’s easy to go through. If using laminated sides the risk is of course higher. Food for thought.
BOSCH PS11-102 12-Volt Lithium-Ion Max 3/8-Inch Right Angle Drill/Driver Kit with (1) High Capacity Battery and Charger , Blue https://www.amazon.com/dp/B00BD5G3UC/re ... UTF8&psc=1
Brad
PostPosted: Fri Feb 04, 2022 8:31 pm
Last Name: Ball
I have one of the pneumatic ones--I've used it on things like heels and necks--great for these purposes-- but I don't use it on sides for the reasons others have mentioned. It's undoubtedly a good tool for that, but I don't feel confident using a tool that aggressive on such thin wood.
PostPosted: Fri Feb 04, 2022 10:21 pm
First name: Toonces
Last Name: the Cat
City: New Smyrna Beach
State: FL
The Elevate rolling pin sander works well. I have the old version with a rubber drum and I imagine the new version is even better. I like to use 100 grit -- 80 grit is quite aggressive.
You should be using it at a slow rpm and with steady control. As with everything when it comes to woodworking -- there are many different ways to approach a task and not everyone will gravitate to the same approach. For sanding the sides, I like to use the rolling pin sander to get mostly there and then follow up with a wood block with 3M Stikit. I also use spring steel slats with 3M Stikit for the curves. I picked this tip up from Mike Greenfield and it allows you to smooth the contours perfectly and easily (no chasing bumps/humps). I find this incredibly useful for the tailback and headblock regions.
PostPosted: Fri Feb 04, 2022 10:26 pm
Last Name: Gleason
City: Kurtistown
State: Hawaii
Zip/Postal Code: 96760
I have the Elevate ones and a couple of inflatable ones. 4 in all. I mostly prefer the inflable ones for what I do. A little more forgiving and easier on the sand paper. I rarely use any of them handheld anymore. I prefer to chuck them in the drill press. Holding the body or neck works better for me. Don't use them a lot, but occasionally they are very useful, so worth having at least 1. If I had to choose between the Elevate ones, I'd go for the larger diameter one.-Bob
“ The meaning of life is to find your gift and the purpose of life is to give it away” Pablo Picasso
These users thanked the author Pegasusguitars for the post: Kbore (Tue Sep 17, 2024 12:14 am)
PostPosted: Sat Feb 05, 2022 1:20 am
I tried motorizing an extra rolling pin from the kitchen. That didn't work out too well :lol:
I think I will just spray glue some sandpaper to it and use it manually - it might be a bit less aggressive.
PostPosted: Sat Feb 05, 2022 6:00 am
Thanks folks, I appreciate the suggestions and comments.
I have a 2 speed cordless, low being 0-350 rpm (controllable).and bought 2 rolls of 120 grit with the sander as the main abrasive.
Now that I'm laminating sides they seem to come out much flatter, so should only need a light touch.
But neck shaping can be a time eater, and I'm hoping to cut down on time and increase control there at the neck and head stock flares.
These users thanked the author Colin North for the post: bcombs510 (Sat Feb 05, 2022 9:06 am)
PostPosted: Sat Feb 05, 2022 5:57 pm
Country: UK
Have to say I wouldn’t dream of using 80 grit abrasive at this late stage of construction. Even if you don’t sand right through you are going to have huge grooves to deal with.
As Colin says 120 grit might be right, maybe 150.
Users browsing this forum: Bing [Bot] and 15 guests
